HELP PLZZ
Old May 31, 2014 | 06:17 PM
Josh Graybeal's Avatar
Car: 1992 Camaro RS Heritage Edition
Engine: 305/5.0L
HELP PLZZ
So I'm went to flush my coolant system today. I noticed when I was putting everything back together that the water in the manifold wasn't draining. There's just a puddle of water right under the water neck.
Does anyone know why and if there's a way to snake the clogged artery, so to speak.
Old Jun 4, 2014 | 07:56 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: HELP PLZZ
i assume because the thermostat is there and closed.
Old Jun 4, 2014 | 08:01 PM
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Re: HELP PLZZ
Did you pull the lower radiator hose to drain it? how much water are you talking about in the cross-over?
Old Jun 4, 2014 | 08:08 PM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Transmission: 700 R4
Axle/Gears: 370 BW
Re: HELP PLZZ
Have you drained the radiator? Is the thermostat still under the neck? Zenish has the obvious answer if the answers are yes. Otherwise you would have a clog and no a snake will probably not help. You would have to use sometime of solvent to remove the corrosion/clog.
Old Jun 4, 2014 | 08:17 PM
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Re: HELP PLZZ
Josh, I would like to give you the benefit of the doubt, and say that you "did" remove the thermostat. (Did you?)
Old Jun 4, 2014 | 11:19 PM
Engine: 305/5.0L
Re: HELP PLZZ
I did remove the thermostat, as well as the lower radiator hose to drain it. But if I stuck my finger straight down into where the thermostat goes, there's just a Little puddle. Maybe about an inch deep.
Old Jun 5, 2014 | 01:28 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: HELP PLZZ
Did you drain the engine block?
Lift the car and crawl underneath.
Remove both the block drains. One drain hole might contain the knock sensor. If no water comes out, poke a small screwdriver in the hole to break apart the scale and sludge.
Once the block is drained the water in the intake manifold will disappear.
Old Jun 5, 2014 | 01:33 AM
Engine: 305/5.0L
Re: HELP PLZZ
Did not do that. Thanks for the information!
Old Jun 5, 2014 | 05:22 AM
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Re: HELP PLZZ
Don't know what you're trying to accomplish Josh, but it sounds like you've done OK. A little standing water here or there isn't gunna harm anything.
92formulalukain
Feb 10, 2015 10:21 PM
Dustin martin
Feb 20, 2012 05:05 AM
VelocitySc0pez
Aftermarket Product Review
22
Sep 14, 2011 04:16 PM
