need help with heater wiring
Old Jul 8, 2014 | 02:38 PM
83z28350's Avatar
Car: 84 z28
Transmission: t56
Axle/Gears: posi rear with 373's
the heat had been taken out of my car and harness was cut out so i went to a junkyard and got a new harness and i purchased the ac delete box and new blower motor i know where everything connects except the red and gray/tan color connectors by the firewall they were connected in the donor but the engine was still in it so i couldnt really follow them to see where they went any info would be great thanks
Old Jul 8, 2014 | 06:04 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: need help with heater wiring
If the car originally had A/C ? it would be wired for a blower high speed relay and a 4th speed( red and tan wires) . If you are retrofitting in A/C delete and fan resistor, the relay and extra speed aren't present. What you are left with is low, med and hi for heat. On an A/C car that would be low, low-med, med-hi and hi <-(uses blower relay). Tan is one of the mid speed and red supplied +12v constant to the blower relay.
But, that's just a guess.
1992 Trans Am
May 10, 2023 07:19 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
