Seems to be running hot
Old Aug 10, 2014 | 08:53 PM
3rdGenHitman's Avatar
Car: 1989 Camaro RS
I have a built 350 in my 89 and when i drove it today (80* day) it seemed like it was running hot. on the side streets n such it was around 230 and on the highway it was around 220. now i was told its fairly normal as long as its not around 240+, but im new to the camaro scene and i was curious what anyone else runs at. it has a 6 inch cowl hood on, but i kno the front end on these doesnt let a ton of air in. it definitely runs cooler with the hood off.
Old Aug 10, 2014 | 09:51 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: Seems to be running hot
is this off of the stock dash gauge? if so they tend to not be accurate at all. mine reads 45 degrees higher then it really is.
Old Aug 11, 2014 | 03:55 AM
Car: 1989 Camaro RS
It's an aftermarket dash panel and gauges. If u look at my pics u can see it. That's another thing I was thinking tho. But when I run it with the hood off it stays right at 180-190. So Idk if it's right or not.
Old Aug 11, 2014 | 12:25 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Checker or autozone usually have IR thermometers they will let you use. Easy to check if your guage is accurate.
If it is indeed reading accurate, sounds like you need to increase the efficiency of your cooling system. Make sure you check all of your components to see if they are functioning properly first.
https://www.thirdgen.org/overheating
Old Aug 11, 2014 | 01:09 PM
Car: 1989 Camaro RS
ya i was thinking about using the ir to check it. but im gonna be tweaking the timing n such tuesday so im going to see if that affects it at all.
Old Aug 12, 2014 | 06:07 PM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
Many posters here feel a 190 degree thermostat is optimum. You might try changing your thermostat. (I assume you have an air dam under your front bumper and that it isn't damaged.)
theshackle
Mar 5, 2017 06:37 PM
BADNBLK
Nov 16, 2016 09:12 AM
ezobens
Aug 19, 2015 10:29 PM
jackhammer
Aug 15, 2015 10:04 PM
