fan burn out
Old Sep 3, 2014 | 06:27 AM
DANNY25SS's Avatar
Car: 92' Formula T-Top
Engine: L98 With Custom CAI
Transmission: BUILT 700R4 with B&M Mods
fan burn out
Monday on my way to work my main cooling fan decided to seize up and burn out literally smoke and all on my 92 Formula.
I replaced it yesterday and now none of them work. I replaced the relay no change. If I jump the brown and orange wire then only the main one works but not the secondary even with the AC on. Any ideas as to what I'm missing could it be the switch in the block or do I have other issues?
Thanks all,
Danny
Old Sep 3, 2014 | 06:53 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: fan burn out
Do you have a fuse that needs to be replaced somewhere in the setup?
Old Sep 3, 2014 | 07:06 AM
Joe Tag's Avatar
Re: fan burn out
If you have to jump the brown wire to hot the fan fuse in the panel is likely blown. Replace it and try jumping the green/white on primary and black or grey wire on aux fan to ground to trip the relay. If no function, try swapping relays to see if the relay is bad. Look in the connectors for burnt wire ends. Jump orange to black/red wire and see if fan works. Check fan grounds. Update what you find and we can go from there.
Edit: you may be powering the fan through the Ign circuit by the way you are jumping it. Take a close look at the fusible link to make sure it's not burnt. Jumping the orange to black/red wire like I said will test that.
sheachopper
Jul 31, 2019 11:27 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
