Removing fan switch-85 TA 305 -qjet
Old Nov 13, 2014 | 10:32 PM
Sonny_T's Avatar
Car: Transam, 85
Engine: 305 HO, 4bbl Carb, G Engine
Transmission: 5 Speed
Fan switch is shot and keeps fan running as soon I turn key on. I checked my relay and it is good. How do I remove rad fan switch between cyl 1 & 3 on passenger side. I tried from top but oil deep stick is on the way.
Old Nov 13, 2014 | 10:37 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Removing fan switch-85 TA 305 -qjet
There's just 1 14mm nut holding the dipstick in place, remove it and you should have better access to the fan switch. The heat shield can be a pain sometimes too - you just gotta' work with the room you've got back there !
( V8 fan switch is on back of PASS side head,.... not the gauge sending unit on drivers side.)
Old Nov 14, 2014 | 09:51 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Much easier to get it out the bottom.
Old Nov 15, 2014 | 11:53 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Ditto this.
Also, make sure you drain your coolant from the radiator.
You can do it without draining the radiator, but coolant will drain out while you swap the switches, causing a bit of a mess.
RazorN8
Jan 7, 2022 11:44 AM
theurge
Aug 21, 2015 12:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
Leggman1
Aug 6, 2015 04:15 AM
