87 Firebird cooling issue
Old Jan 6, 2015 | 07:52 PM
dmain78's Avatar
I have an 87 firebird with a 2.8L. I have replaced the heater control valve 3 times. I don't drive the car at all on the road due to work that needs to be done. As soon as the temperature gauge gets to normal operating temperature, I look at the valve and it has started leaking. I dont know if it has to do with the heater controls inside or if there is a blockage somewhere under the hood. I do know I need to rebuild the cooling system at this point, but wasn't sure if there was a known issue with these heater valves. Also, when does that vacuum line going to the valve have vacuum pulled on it?
Old Jan 11, 2015 | 12:09 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 87 Firebird cooling issue
They are known to leak over time. your best bet is to find one, possibly you can get one from an autoparts store.
Old Jan 11, 2015 | 05:47 PM
dmain78's Avatar
Yes the valve is available. They're $20, but I've replaced it 3 times and it keeps leaking and I never drive it. I replace it, start the engine and as soon as it starts heating up it starts leaking. I replaced all the hoses and clamps.
Glowsock
Jul 24, 2025 03:15 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
TheExaminer
Aug 26, 2015 04:59 PM
Bryan F
Aug 18, 2015 02:28 PM
Leggman1
Aug 6, 2015 04:15 AM
