86 firebird 2.8 fan not working...where to start
Old Feb 6, 2015 | 04:51 AM
  #51
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Originally Posted by camarotucker
So what year was the change from ecm controlled fan to fan switch?
Old Feb 6, 2015 | 04:54 AM
  #52
willexoIX's Avatar
Originally Posted by greasyfox18
No luck yet...all looks good in the harness....im still not understanding why when i unplug the censor under the throttle body then start it up it runs but when i shut it off and plug in in they wont run when the engine
Is hot....
Replace that coolant sensor. Appears I was wrong and on the 86 that sensor does play a role in the fan coming off/on.
Old Feb 6, 2015 | 08:12 AM
  #53
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 86 firebird 2.8 fan not working...where to start
Everythign I've been able to find (hours of searching here on the site mainly) indicates 1988 was the year they started going to ECM controlled fans.
Old Feb 6, 2015 | 12:24 PM
  #54
willexoIX's Avatar
Thats interesting. My 89 never had the ecm controlled fan; was it different for firebirds?
Old Feb 6, 2015 | 12:42 PM
  #55
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
All that info that I'm posting is from GM Pontiac 1986
Old Feb 6, 2015 | 12:45 PM
  #56
willexoIX's Avatar
Originally Posted by mantaguy
All that info that I'm posting is from GM 1986
So I guess the early cars had the ecm controlled fans, then the later ones didnt. At least thats what I gather, even though it makes more sense the other way around.
eightsixseven
Dec 16, 2024 01:50 PM
theshackle
Mar 5, 2017 06:37 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
justin57
Aug 20, 2015 07:05 PM
86Base
Aug 8, 2015 01:34 PM
