89 Camaro Fan Shroud Bolt
Car: 89 GTA
Axle/Gears: 12 bolt 3.73
So I'm replacing the radiator on my Camaro, and I need the bolts that mount the fan shroud. A somewhat thorough google search was fruitless and O'reilly was no help. Are they a part I can find retail, or do I need to go take them off a parts car?
Re: 89 Camaro Fan Shroud Bolt
I haven't worked on an F-Body in a while, but I think I remember there being metal clips that snap onto the side of the radiator and then the bolt goes through those. I was at Sears and noticed they sell several sizes of the clips there. I wish I could remember what they're called. Anyways I'm sure if you can buy the clips there you could find bolts that would fit. I don't remember ever needing any super special bolt or anything. Might want to use a washer so the bolt head doesn't mess up the plastic of the radiator when tightening it down.
Yes indeed, those are called Tinnerman clips, formally; but most everybody refers to them as "fold-over nuts" or the like.
You can get em at any parts store, even AZ and the like. Use the bolts that have the captive washer and the pointy end (body bolts), not regular ones. Get clips and bolts of the same size at the same time to avoid trouble. Should probably be 6mm. Pay attention to whether the clips are for sheet metal screws or for regular bolts; they make both kinds.
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
If you get lucky, you might actually find someone at one of the parts stores who knows what you are asking for.
either the Help! Section, or where the hardware in blister packs are.
Nowadays they are known as speed nuts also. If you ask for those they might actually know what your talking about, lol.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
http://www.clipsandfasteners.com/v/v...catalog105.pdf
Clips and Fasteners calls them U Nuts
eightsixseven
Dec 16, 2024 01:50 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
