Heater hoses question
Old Mar 24, 2015 | 10:48 PM
TX-SleeperC5's Avatar
Car: 1987 Trans Am GTA
Engine: 5.0 TPI
We have an 87 GTA. The car has a "heater control valve" above the passenger side valve cover.
My question is, can I eliminate the control valve and just run the heater core lines straight to the water pump / intake connection point and the other line to the radiator connection point ?
Thanks in advance for your help.
Old Mar 25, 2015 | 07:49 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: Heater hoses question
Yes. The supply side is the intake manifold. The return is either the water pump OR the radiator.
Old Mar 25, 2015 | 10:54 AM
Engine: 5.0 TPI
I will need to double check but I believe there's a fitting on the intake and for sure there's a fitting on the radiator.
Old May 8, 2015 | 09:12 PM
scott j's Avatar
Car: 90 camaro rs
Engine: 5.7 tpi
Transmission: t-5
Axle/Gears: 373
would you know how to run heater lines . trying to put aluiminuim radiator that only has upper and lower hose hookups. 87 5.7 tpi with oilcooler
Old May 9, 2015 | 08:07 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
You need a "return" from the heater core. Without a fitting in the radiator, as-is, your choices are: 1) Have a fitting drilled and welded into the radiator tank. 2) remove plug and use (one of?) the water pump fittings. 3) Find a T fitting* and return it into one of the main radiator hoses.
* something like this or this or this.
Old May 9, 2015 | 12:49 PM
scott j's Avatar
Car: 90 camaro rs
Engine: 5.7 tpi
Transmission: t-5
Axle/Gears: 373
So driver side port on heater core goes to radiator after t off for oil cooler?
Passenger port line goes to intake manifold and t off to other side of oil cooler.
Old May 15, 2015 | 02:01 PM
scott j's Avatar
Car: 90 camaro rs
Engine: 5.7 tpi
Transmission: t-5
Axle/Gears: 373
Any picture of heater hose diagram with oil cooler
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
redmaroz
Aug 16, 2015 11:40 PM
