Aftermarket Cooling Fans.
Old Apr 30, 2015 | 11:08 AM
DemonYusuke's Avatar
Car: 1991 z28 L98 Spec
Engine: 5.7 350 TPI 245\345
Transmission: 700 R4
Ok guys, I am having a problem with my fans randomly not working.
I have an aftermarket controller set up so that they come on at 190 or when i turn the ac on. This worked great until recently when the fans seemingly for no reason stop running. I thought it was when they got hot maybe, but I have done cold test.
I can walk out and pop the hood wire the relay to the battery and they pop on, an hour later walk out to do the same thing and they dont run at all. Im so confused by these fans so I am considering a couple cheap replacement just to get me on the road for now.
http://www.ebay.com/itm/2X-14-SLIM-PULL-PUSH-1730-CFM-2250-RPM-RADIATOR-ENGINE-COOLING-FAN-MOUNT-KIT-RED-/191002258308?hash=item2c789f2b84&vxp=mtr
anyone have any recommendations I linked a seemingly decent pair above.
Old Apr 30, 2015 | 11:35 AM
Re: Aftermarket Cooling Fans.
An Update kind of, I went out again and tried and the fan started to turn and then stopped. So i am thinking the fans have finally had it. They are 24 years old.
Old May 26, 2015 | 03:02 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
I'd suggest one of these bad mama jammas....its a RamCharger (Intrepid/Stratus) dual fan/dual speed fan assembly. These are tested OEM fans with one if my control harnesses. But, you can source the fans yourself at any pick n pull yard. Just check for any bearing noises and excessive amperage draw. They measure approx. 18.5x26x3 inches overall.
Old May 27, 2015 | 07:47 AM
sheikss's Avatar
Car: 88 Trans Am GTA
Axle/Gears: 12 bolt 3.73
What cfm do those fans pull?
Old May 27, 2015 | 09:01 AM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
These are rated @ 2800 CFM on low speed and 4000 CFM on high. They are wired in series through the motor windings so the control harness for them is slightly different than those for TPI/LT1/LS1 which can be wired for dual speed with a relay bank as well.
Old May 27, 2015 | 09:57 AM
sheikss's Avatar
Just switched to a becool radiator to help solve my temp problem but want to switch fans also. Was looking at the derale that pull 4,000 cfm but would perfer oe stuff. Whats the setup from you cost? Have been wanting to get your express down kit for my 88 gta as well.
Old May 27, 2015 | 10:50 AM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
I'll PM ya-I don't want to highjack the OP thread here.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
