radiator fan help. secondary won't spin
Old May 3, 2015 | 09:02 PM
89 formula TPI's Avatar
Engine: LB9 5.0L TPI
Axle/Gears: 9-bolt Borg Warner, 3.45
89 formula with dual fan set up. The car will heat to 240 according to my laser temp gun... the first fan comes on intermittently, only stays on briefly but not enough too cool it off then stops. Seems to kick in randomly at diff Temps sometimes 220 etc. The second fan never spins...even if I turn AC, heat or defroster on.
Any ideas? I'm more concerned the first one doesn't seem to be working right. Recently flushed coolant and replaced coolant temp sensor, radiator cap and stock thermostat.
Old May 3, 2015 | 11:07 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
Re: radiator fan help. secondary won't spin
could be the fan switch on the rh side of the block.
could also be the relay and it could be the ECM
try one of the link in this thread for the service manual, it will give you a trouble tree to follow and ways to test it.
https://www.thirdgen.org/forums/cool...ce-manual.html (1988 Firebird Service Manual For Download)
Old May 4, 2015 | 07:56 PM
thanks but the link wasn't working. do you mind resending?
Old May 4, 2015 | 09:16 PM
alex722607's Avatar
https://www.thirdgen.org/forums/tech...ce-manual.html
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
64goatman
Sep 9, 2015 01:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
