92 RS 305 TBI Running Hot
Old May 18, 2015 | 08:25 AM
92RSCamaro1's Avatar
Car: 92 Camaro RS
My 92 Camaro seems to be running very hot. The temp gauge shows it runs about 260 almost in the red. I have a new temp sensor and a 160 degree thermostat. The fan is also wired to run constantly. Not to sure why the sensor will still read that is is very hot. Any suggests to what I can look at? Thanks!
Old May 19, 2015 | 08:44 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 92 RS 305 TBI Running Hot
What does it read when you are cruising on the highway? Any cooler?
Also, our factory gauges are notoriously off...I'd get an infrared thermostat and see what the temp is at the water neck. My gauge reads almost 240 when the 212* fan switch turns the fans on.
Old May 19, 2015 | 04:34 PM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
Air dam missing? Thermostat stuck?
Old May 20, 2015 | 08:48 PM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Have you pulled the radiator? They are bad about getting leaves and stuff between the radiator and the condenser. If that happens airflow is pretty much cut off.
Old May 20, 2015 | 09:19 PM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
Run down the cooling system basics;
Check condition of the radiator:
- fins clear of debris, not bent/mangled
- no visible leaks from seals or hoses
- radiator cap gasket in good shape
- not blocked (leaves/debris)
- with engine at temp check for cold spots on the radiator (usually at the bottom, evidence of blocked passages)
Check condition of the air dam:
- not missing/broken
Check condition of the fan(s):
- if electric, check for proper operation
- if mechanical, fan clutch not worn out
Check Hoses:
- Not kinked/collapsed/leaking/steam leak. Look for evidence of pinhole steam leaks in the form of yellowish green deposits or "snot" at gasket areas and around hose ends.
Check water pump:
- no sign of leakage from weep hole
- no odd noises
Check coolant:
- proper color/mixture
- proper fluid level (has the system been "burped" to remove all air?)
- does system pressurize (engine at temp, thermostat open, radiator cap on and upper and lower hoses not soft)?
Check heater:
- does hot air blow from the vents with engine at temp (heater core not clogged?)
Other things that can effect engine temp are detonation, trans issues (auto trans generate a LOT of heat), mineral deposits in the engine/heater core/radiator that block coolant flow (from running tap water), and improper timing.
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Jae992
Aug 27, 2015 09:07 AM
