Need more help troubleshooting temp gauge
Old May 31, 2015 | 07:44 PM
hihighost's Avatar
Car: 1987 Camaro
Engine: Carb'd L31 Vortec 350
Axle/Gears: 4th gen torsen / 3.23
Hey all,
I've done extensive research but I'd like more specific insight on an issue I'm having.
I just swapped a carb'd L31 into my 1987 camaro. Previously a carb'd LG4. My temp gauge is not working properly. The thermostat, temp sensor, and sending unit are new. The gauge worked prior to the swap. Now, the gauge is either stuck past hot, or will occasionally fluctuate to 220 and then back to hot. This happens regardless of whether the sensor is connected or not.
Any ideas where I should start? Once this rain subsides I will take a voltage meter to the sending wires, at the sensor and gauge, and update my findings. Could this be a ground issue? Voltage issue? A description of all power and ground wires related to the CTS would be great.
I appreciate any help. Thanks.
Old May 31, 2015 | 08:18 PM
nytmare's Avatar
Car: 86 z28 Iroc
Engine: 350 t76 turbo
Axle/Gears: 3:23
Re: Need more help troubleshooting temp gauge
I would say make sure you hooked up all the grounds on your engine block.
Old May 31, 2015 | 10:15 PM
hihighost's Avatar
Car: 1987 Camaro
Sounds good .. Is it possible to simply re-ground the temp sensor wire? Or can this be a ground issue seperate from the CTS sending unit? Any other grounds that affect the temp sensor?
Old Jun 1, 2015 | 02:53 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
The threads on sensors and senders are grounding them to the block/engine.
A "sensor" is what sends information to the ECM.
A "sender" sends information to a "gage" not connected to the ECM.
I recently was reading my trusty "Chilton's" and it mentioned a anti-seize compound that was dialectic. The closest I've come to that would be the "Copper" type.
It was under the o2 sensor section so I guess there worried about not getting a good enough ground with traditional silver colored anti-seize.
Old Jun 1, 2015 | 04:12 AM
nytmare's Avatar
Car: 86 z28 Iroc
Axle/Gears: 3:23
Like Ron said they get ground through the block. Make sure you hooked the grounds at the back of the engine usually grounded under a bolt through the bell housing bolt.
Old Jun 1, 2015 | 09:16 AM
hihighost's Avatar
Car: 1987 Camaro
Noted, thanks everyone. I know which grounds you're referring to. I'll make sure they're connected and seat properly and will let you all know.
Bubbajones_ya
Jul 6, 2024 08:32 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
corey8084
Sep 17, 2015 02:56 PM
