radiator fan switches
Old Jan 10, 2016 | 08:36 AM
kt350's Avatar
Car: 88 iroc-z
Engine: 5.7tpi
Transmission: auto
can anyone help with a photo and part numbers for the switch in the passenger side head? I've got a 1988 5.7 IROC and the switch in mine has a two pin plug and all the ones I've found online are a single pin which I suspect is the one in the block near the knock sensor in earlier models
Old Jan 10, 2016 | 05:06 PM
kt350's Avatar
Car: 88 iroc-z
Engine: 5.7tpi
Transmission: auto
Re: radiator fan switches
This is what the one in my car looks like
This is what the sites say will fit
Old Jan 10, 2016 | 05:19 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
The single is "correct" the dual wire is a replacement.
Old Jan 11, 2016 | 08:25 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Heres the part numbers and fan"on"temperatures.
Part # TFS8 = 204 on
# TFS4 = 213 on
# TFS1 = 224 on
You should be able to have these part numbers cross referenced if necessary.
You can still use the stock 195* thermostat with these switches.
There are switches available from Jet Performance = # 60600 at 195* on and 185* off.
also
Hypertec = # 4028 at 200* on and 185* off.
I would use a 180* thermoset with either of them.
Old Jan 12, 2016 | 03:31 PM
dcd2236's Avatar
Car: 1987 trans am, 1988 Formula
Engine: 305 LG4, 305 LB9 TPI
Transmission: 700R4 in both
What was the part number for the grand national fan switch that is a direct bolt in for these cars? I think it comes on at 204 F which is what I would want before 220 on primary and 238 on secondary fans.
Old Jan 12, 2016 | 05:38 PM
TTOP350's Avatar
Hypertec stuff = was discontinued.
looks like they switched suppliers for 1 of the switches b4 they discontinued them.
http://www.summitracing.com/parts/rfw-ar34/overview/
Old Jan 12, 2016 | 08:38 PM
Engine: TBI,5.0
What's wrong with the one 204 * "on" switch that I listed in the post above.
Old Jan 13, 2016 | 08:29 AM
dcd2236's Avatar
That may be one of them. I found this one I was looking for. ts-138 standard motor products.
Old Jan 13, 2016 | 06:11 PM
Engine: TBI,5.0
How much is that switch ?
Summit Racing has it for around $83.00
89irocz355
Oct 8, 2023 12:59 PM
89irocz355
101
Sep 19, 2016 04:05 AM
89irocz355
Exterior Parts for Sale
25
Apr 7, 2016 03:34 AM
89irocz355
Dec 26, 2015 07:44 AM
89yellowntxroc
Dec 22, 2015 10:32 AM
