No vacuum at H
Old May 22, 2016 | 10:21 AM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
No vacuum at H
Sorry about the title, the computer somehow submitted the post before I finished typing.
My heater was only working on defrost so I took apart the heater controls to try to fix the problem these cars have with the selector where all the vacuum hoses plug in. I soaked the rubber disk in brake fluid then replaced the plastic clip that holds the two pieces together with a nut and bolt like I've read you're supposed to do but it still doesn't work. In fact it works exactly the same as when nothing is plugged into the hoses at all. I feel no vacuum coming from any of the hoses. Where do these hoses get their vacuum from? Is there another weak spot that I should check?
Old May 23, 2016 | 06:41 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: No vacuum at H
The hose gets vaccuum from a line thats plugged into the intake manifold
behind the carb.
The hose runs to the firewall and then splits and runs off a T connector to both
the cruise control vac. orb and then thru the firewall to the heater control.
Start at the manifold connection to check for vac/bad hose and work toward
the firewall.............
I have the same issue!
Pretty sure its a vac. line leak/plug/pinch behind the dash.
Having defrost only is the default mode when there is a vac. problem.
2012sergen11
May 20, 2016 07:36 AM
azcamaro
Apr 13, 2016 05:26 PM
Mastiff
Apr 8, 2016 10:56 AM
thomashearts
Carburetors
Apr 3, 2016 08:28 PM
justpushyouoff
Mar 29, 2016 07:09 AM
