2 pin connector with diode on front side of a/c compressor!!
Old Jun 19, 2016 | 10:21 PM
stahrman0612's Avatar
Car: 1986 Trans-Am
Engine: 305 4 bbl
Transmission: 700R4 auto
Axle/Gears: posi
My A/C compressor will sometimes not kick on when I turn on my a/c. If I open the hood and wiggle this little connector w/diode it will kick on and work. I ordered a new connector and it is still doing the same thing!! Does anyone know what the "HELL" is the problem and how to fix?? It's getting old to have to wiggle this thing every time I want to use my a/c!!!!!! Any help appreciated!!
Old Jun 20, 2016 | 01:42 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: 2 pin connector with diode on front side of a/c compressor!!
You are on the right track - no doubt a corroded connector. When you replace it, also make sure the pins on the coil are clean.
Old Jun 20, 2016 | 02:09 AM
Car: 1986 Trans-Am
Engine: 305 4 bbl
Axle/Gears: posi
I did put the new one on and it is doing the same thing. I sprayed some electrical cleaner on the male connector on the compressor and then flipped the 2 pin female connector around. So far so good....hopefully that will fix it?? I'm sure it's just not getting a tight solid connection.
Old Jun 20, 2016 | 02:22 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
The best electrical cleaner is fine sandpaper. If you are confident that all the connectors are good and it still makes/breaks contact with a wiggle your clutch coil is bad. Search "Four Seasons 47298" for a replacement. With all the partial engagement your clutch might be damaged anyway so this would be a good fix. Clutch can be replaced without opening the system.
88IROCvertZ
Jun 24, 2016 09:36 AM
David Fite
May 5, 2016 09:31 AM
malcontents
May 2, 2016 08:52 PM
sleprock
Interior Parts Wanted
Apr 5, 2016 01:58 PM
backtothe80s
Mar 29, 2016 01:02 PM
