Re-Adding AC
Old Jun 21, 2016 | 11:36 AM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Re-Adding AC
Hi Guys,
When I had purchased my car, someone had already taken the liberty of removing the AC Pump and the hi\low pressure lines. They did leave the condenser and collector, and I assume the evaporator is inside the shroud. The Evaporator\Collector are from a 1990 Formula, although I could swap in the one from the 84 TA if there's any difference.
Since I'll be dropping in my 350 next week to replace the 305, I was hoping to get AC hooked up as well during the process. I am keeping the V-Belt drive for the time being. Does anyone know of a place I might be able to source the parts? AFAIK I'll need the pump, the pulley, and the lines. Also, what refrigerant would be best since it's a completely empty system presently?
Thanks!
Old Jun 23, 2016 | 08:44 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Re: Re-Adding AC
used parts section?
I just want to remind you that the A/C drier needs to be replaced once you've opened the system for a length of time. And remember that before filling with expensive gas, you must apply a vacuum pump to the system, for two reasons: 1. to check for leaks (make sure it holds a strong vacuum for a while) and 2: to evaporate all the water from the system.
Old Jun 23, 2016 | 11:16 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Re: Re-Adding AC
I'll probably bring it in to get checked\filled. I imagine it won't cost much more than just buying the fluids myself.
Thanks for the info on the dryer. I suspected but I wasn't sure. Can you buy these new anymore?
I've seen a few threads about using\converting to other refrigerants. I'm guessing if I bring it in they won't fill it with anything other than R-134A, though.
Old Jun 24, 2016 | 12:53 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
Re: Re-Adding AC
http://www.rockauto.com/en/catalog/c...cumulator,6972
rockauto $12~
its a common thing, probably daily somewhere around the world somebodys A/C system opens and fails and they need a drier today. Parts like that so common, draw the attention of suppliers who can manufacture it or simply acquire it/know where to get it. The problem finding something new is more likely if the part in question almost never fails or needs replacement.
BG1959
Jul 20, 2016 02:22 PM
74SpiT
Mar 25, 2016 03:25 PM
Troy Hemp
Mar 24, 2016 07:39 PM
azcamaro
Mar 23, 2016 07:24 PM
Troy Hemp
Mar 23, 2016 07:06 PM
