Wiring new Holley EFI to existing '89 Dual fans
Old May 22, 2016 | 09:09 AM
Abubaca's Avatar
So I had asked in another thread about going with a stand alone fan control kit, or using the (new) Holley ECM. "IF"...I go with computer control, how would I wire it? On the Holley side, I have multiple programmable outputs. Simple enough. ...on the car side however.....looking at the '89 diagram, it looks like it's the gray to the AUX fan relay, and Dark Green/white to the main fan relay. Is it as simple as that? Two wires from the ECM to two wires for the fan relays?
Old Jun 26, 2016 | 08:16 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: Wiring new Holley EFI to existing '89 Dual fans
you would use the ground wires that each fan uses to turn on from the switch or ecm and use the ground outputs from the holley efi to control them
DonW
Carburetors
24
Apr 8, 2016 10:53 PM
instaldave
Apr 7, 2016 06:14 AM
yevgenievich
South Central Region
Apr 3, 2016 08:56 AM
BobKnake
Mar 28, 2016 09:56 AM
iiAmDomo
Aftermarket Product Review
Mar 24, 2016 02:27 AM
