1991 camaro rs overheating when going up a hill or with the A/C on.
Old Oct 9, 2016 | 10:52 AM
tony-pr's Avatar
I have 1991 camaro RS 305 TBI. The engine was rebuilt and bore over 40, long headers and dual exhaust. It overheats only when going up a hill or with the A/C on.
I’d tried almost everything. Fans always on, new three-line aluminum radiator, tried running it with and without t-stat, hose not collapsing, timing is perfect (verified by experts), new water pump. Searched every forum and the web for answers, can’t find anything.
I believe that it is running lean. Checked a spark, looked as lean. Also tested the AFR with a wide band, varied from 14.7 to 16 idling. Fuel pump pressure is 12psi.
Thank you for your help, getting kind of desperate, been almost a year trying to fix this problem.
Old Oct 28, 2016 | 09:19 AM
1987L69's Avatar
Car: 1984 Z28
Engine: LG4 305/4bbl for now
Transmission: 5-Speed
Axle/Gears: 3.23 Posi
Re: 1991 camaro rs overheating when going up a hill or with the A/C on.
Try an aftermarket temp gauge. just to make sure its overheating. also check your air dam under the radiator, it sounds like an air flow issue.
Old Nov 3, 2016 | 03:02 PM
tony-pr's Avatar
Thanks for your response. I just got my hands on an infrared gun. I point it at the t-stat housing and when my gauge marks 220+ the gun is in the high 190s (like 198). Is there another place where I should point the gun at?
Also, what I understand from what I found on the internet is that the sensor next to the t-stat housing sends coolant temperature readings to the ECM and that the sensor on the driver side of the engine block ( just under the manifolds) is the one that sends the readings to the gauges, is that correct?
Detroit Speed
Members Camaros
457
Jan 25, 2023 08:34 AM
Mattkovitch
Jun 26, 2018 09:22 PM
PUNK AF GTA
Dec 14, 2016 11:56 AM
La Swope
Sep 16, 2016 03:32 PM
Cody Willey
Sep 10, 2016 05:38 PM
