Factory gauge reading low
Old Oct 17, 2016 | 04:20 PM
1987L69's Avatar
Car: 1984 Z28
Engine: LG4 305/4bbl for now
Transmission: 5-Speed
Axle/Gears: 3.23 Posi
So I have a 160* T-stat in my 84 LG4 (please no negative comments about it being too low of a temp) and my factory gauge reads about a 1/16 of an inch below the middle mark between 100 and 220, which to me should be 160* mark. How accurate are the factory gauges and should I replace my sending unit?
Old Oct 17, 2016 | 05:02 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Factory gauge reading low
They're not all that accurate, but yours sounds about as good as they get. Does it stay at that level while idling for a while, at startup, or after extended driving? Also depends a lot on ambient temperatures.
Old Oct 17, 2016 | 05:25 PM
1987L69's Avatar
Car: 1984 Z28
at a cold start up my gauge reads below 100, which is correct, then after driving it reads 1/16 an inch below the middle mark between 220 and 100, and stuck in traffic with the AC on it reads slightly higher.
Old Oct 17, 2016 | 05:49 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Sounds like your cooling system is doing a fine job and everything seems normal. If you want more accuracy get an IR temp gun from Harbor freight or somewhere and point it at the thermostat outlet neck area after your thermostat opens
johnbhm
29
Aug 28, 2017 04:30 PM
T-Top T/A
Oct 13, 2016 09:08 AM
zya5point0
Oct 12, 2016 01:59 AM
DirtShaman
Oct 9, 2016 03:38 PM
rads84n94camaro
Oct 6, 2016 09:48 PM
