Mechanical fan
Car: 1985 Z/28
Engine: L98 Carbed
Axle/Gears: 9 Bolt Posi 3.45
Mechanical fan
I'm putting together an 85 Z28 basically from boxes of parts. This a TPI motor. I'm now getting ready to install the cooling system. I noticed in my parts that I have an older copper radiator and a mechanical fan. Was this an option?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Mechanical fan
85 tpi had a single electric fan.
The radiator should have plastic tanks and aluminum core.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Mechanical fan
Don't really matter much; but I'm pretty sure that the 85 fan was a 1-year only fan too. The blades were different that year compared to every other fan I've ever seen on a third gen. I noticed this "weird" blade style on the 85 TPI and 85 MFPI cars; but that's it.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Mechanical fan
some 82s had a copper/brass radiator-original in mine was copper and I found one on an apparently original CFI '82 z 28.Did also find an aluminum on a 4/82 CFI T.A. though...Mechanical fans were used on LG4s and LU5 v8s through '85.As noted above,83-85 early design electric fans did have curved,swept back blades instead of straight blades like 85.5-later design.
