Fan Switch not functioning!
Old Mar 29, 2017 | 09:11 AM
BlackBerlinetta's Avatar
Car: 86 Berlinetta
Hey all,
I have an 86 camaro berlinetta vin H. I am having issues getting the fan to kick on with the fan switch. The green wire that grounds the circuit and allows the fan to come on is good, and fan turns on with AC. I have bought two new switches. The first I put in between #6 an #8 cylinders. I purposely let the motor get hot and despite the temp gauge reading above 240 it never grounded the circuit. I put the other switch in the head next to #1 cylinder, but am getting the same results. I can ground the wire and the fan will run with the key, but I would rather this function properly. Any ideas?
Old Mar 29, 2017 | 12:18 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: Fan Switch not functioning!
There can be a lot of reasons why the electric cooling fans wont work reliably.
Add this in parallel to the existing fan relay trigger wire. Works like a charm.
http://www.autozone.com/cooling-heat...267187_69565_0
Have the switch tie a ground in to the relay, adjust your temp on the thermostat switch and your are good to go.
Old Mar 30, 2017 | 08:14 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
With my factory temp gauge the fan would not come on until it read about 260 even though the aftermarket and IR gun read about 235. Many of our factory gauges are very off.
Old Mar 31, 2017 | 07:16 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Stock fan switch on temp, 238°F.
AutoZne, sw505, 215 (slightly cooler than ecm controlled fan temp).
Old Apr 21, 2017 | 06:46 PM
JA411's Avatar
Get the proper switch. They are different between engine sizes. Do not put teflon tape on switch, it won't ground the circuit. Put in with liquid teflon only.
Joe
