Throttle body hoses
Car: 1987 IROC
Axle/Gears: Borge Warner
Throttle body hoses
I did a radiator swap today and bought generic heater hoses in 1/2, 3/8, 5/16. My plan was to replace the hoses attached to the throttle body on my 87 IROC with 350. I removed the throttle body to replace the T-stat and wanted to replace all the hoses but the radius of the bends are too tight on a couple of them to put on without kinking them. So what do you guys use for replacement hoses on the throttle body?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Throttle body hoses
Its called "vacuum" hose or "vacuum" line.
http://www.autozone.com/fittings-and...recsPerPage=68
Hard "vacuum" lines most likely at "Pick N Pull" if your lucky.
Hoses coming from the "Charcoal Canister" are different. That is "Fuel" line.
Looks like this.
Also the "canister purge valve" (red arrow) should be replaced every once and awhile. It has delicate components that eroded from gas fumes/etc. = http://www.autozone.com/engine-manag...alve/68757_0_0
Looks like this.
Car: 1987 IROC
i am try to source the water hose that goes from the engine block above the water pump to the throttle body. it is a short 1/2" hose maybe 4"long ,but it makes a a sharp 180° turn. aim thinking of pulling the hose nipple out of the engine block and plugging it. then figure out a way to plug the heater hose bypass.
Engine: Lb9
Transmission: M20
Engine: TBI,5.0
Now I see what your looking for.
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
You should just bypass the TB Here is a copy of a thread with the part number for a Goodyear hose. Goodyear no longer makes it but the part number is still good. I ordered this hose from Amazon and some hose nipple covers to plug up the open TB inlets. this hose goes from the intake directly to the heater valve.
It is a Goodyear Hose. I was able to find it online at Autozone. If you go to their website and do a search for 63069 it will pull up the hose. You can order it from there. That hose will work much better than the hose I've got now. Thanks iamiroc
