Cooling fan wires
Car: 88 Trans AM
Engine: 5.0 TPI
Transmission: BW T5
Cooling fan wires
I have an 88 Trans AM with a 5.0 TPI engine. I was wondering if anyone had a stock radiator fan setup?
I have bought the car from someone who decided to run the radiator fans off an aftermarket switch with relays and a messy wire job. I was wondering if someone can post photos of the wires running to the relays up along the passenger side and where they are connected. I have diagrams but I would appreciate if someone took time to take photos for visual aid.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Cooling fan wires
Do you have a Single fan or dual fan?
