83 TA - AC wiring
Old Jun 3, 2017 | 03:24 PM
BZ83TA's Avatar
Car: 1983 Trans Am
Engine: 350 ci, Performer RPM package.
Axle/Gears: 7.5", Detroit TrueTrac, 3.73
83 TA - AC wiring
Hey all,
I'm totally changing my AC setup and am using a SAnden style compressor / March performance serpentine kit.
I am assuming I can hook that up with existing wiring and use the factory accumulator, condensor, and evaporator with no issues.
Does anyone know if the AC wiring is at all connected to the ECU? I'm also planning to tear out as much wiring as I can as I've already moved away from the stock wiring for the gauges, fan, ignition, and have an aftermarket EFI (not much left that I need beyond wiring for the wiper motors and pumps!
Old Jun 4, 2017 | 09:52 AM
Re: 83 TA - AC wiring
In 83, no, there's no connection to the computer whatsoever.
Yes all of the other AC system parts will work fine. They really don't care too much about the identity of the pump; to them, it's just a "black box" that produces pressure and flow. As long as its pressure and flow are in the right range (which is pretty forking wide considering the "precision" level of the original R-4), it'll be essentially transparent to the other parts.
Old Jun 4, 2017 | 10:09 AM
BZ83TA's Avatar
Car: 1983 Trans Am
Great to know, thank you!!
Modify Heavily
Nov 5, 2016 10:35 PM
ndndndnd
Nov 1, 2016 08:47 AM
Billgluckman
Oct 23, 2016 09:38 AM
CCrockett86
Oct 3, 2016 12:32 AM
Nik Smith
Sep 14, 2016 04:43 PM
