A/c clutch stick on
A/c clutch stick on
Hi, i have a 85 camaro which has a/c before, but one of last owners deleted it. Missing parts are condenser, hoses and even compressor. I have found a complete set with all a/c 'in-freon' parts in a junkyard. The evaporator seems OK, but i have another one, the condenser is like brand new, and parts were all assembled, si no water on it. There is a little fréon on it, but vert very low pressure.
The compressor turns good, but the clutch is stuck on. Do you think it worth giving it a try by removing the clutch, clean the rust, then réassemble it? Dont want to spend 7-800$ on a/c system, but maybe change system o rings, then fill it with fréon. Whats the cheapest way to repair compressor without buying a rebuild or brand new?
Re: A/c clutch stick on
Yes, but the compressor itself is not brand new, so i prefer to fix it like i can (if possible), then fill the system, maybe ill be lucky and the compressor will works well. Worst case i will buy a rebuild if compressor is bad.
is it possible to fill the a/c with cans without doing the vacuum with the professionnal machine? I know i cant empty a/c myself by law, but it ils already empty.
Before filling it, i plan to change system o rings at least.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Saving Cold Cash
Now the performance will be a bit shy of optimum due to the fact you started out with air in the system instead of only refrigerant.
After you do that your mixture will be 27% air, 73% refrigerant.
However if you the open the schrader valve, to release the pressure after running the system to test/mix the gas, then recap it before new air enters, then recharge the system, your air-refrigerant ratio will improve to 8% air, 92% refrigerant.
But even without that purge/second recharge you might find the AC to be plenty cold.
O-rings are made from different materials based on the type of system oil you’re going to use, so select the correct ones.
Also keep in mind you should use a low-side gage to monitor the pressure, the correct type of oil depending on the type of refrigerant, and a new desiccant (accumulator) can.
Happy Racing !
Nitromethane Smells Sweet When Burning, But Please, No Roasting Marshmallows On The Zoomies
