Hot 383 stroker - 92 Camaro
Old May 26, 2017 | 04:26 PM
Hot383's Avatar
Want a title? Post!
92 Camaro with new 383 aluminum head stroker 450 Hp, Stainless Works Headersa and complete exhaust system. MSD Atomic EFI, Be-Cool Aluminum Rad, and 3300 CFM Flex-a-lite electric cooling fan set up.
While running at highway speed 45 - 80 MPH runs cool 170. In traffic runs 230.
NO air to rad. Any fixes?
Old May 26, 2017 | 04:36 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: Hot 383 stroker - 92 Camaro
Make sure your front end ducting is in there to prevent loop flow.
Old May 27, 2017 | 03:45 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Check fan "polarity".
A fan will spin in two different directions just by switching the wires from positive to negative or vice versa.
Its difficult to tell because if the fan is against a radiator your bound to get some air blow back.
Run one of the wires to positive on the battery or just wait for it to start on its own and closely check the spin direction.
If the fan is in the engine bay it should "pull" air through the radiator into the bay.
If the fan is in front of the radiator it should push air through it into the bay.
You would be surprised at how many time this happens because most fans have two black wires. Very easy to get them crossed.
Old Jun 16, 2017 | 03:30 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
What temp is the thermostat? What is the on temp for the fans? How much timing are you using? How old is the coolant? How much crap is in front of the radiator? 230* is the temperature they run stock so it's not that hot in reality.
Old Jun 20, 2017 | 10:08 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I would say this is normal. Make sure your fan is working properly. Use an IR gun to check temps at the radiator hose. It's common that they read not very accurately. As long as you're not boiling over it's ok.
Old Jun 20, 2017 | 10:49 AM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
overheat at idle = fans
overheat at 35+mph = radiator
L67ss
Theoretical and Street Racing
May 26, 2017 12:11 PM
cwarta
May 26, 2017 10:58 AM
Whodat
May 24, 2017 02:30 PM
jaweiss
May 23, 2017 07:10 PM
wkropp16
May 23, 2017 01:49 PM
