3.1 L camaro exhaust fan malfunction
Old Jul 1, 2017 | 08:19 PM
sherrythecamaro's Avatar
Want a title? Post!
hey guys, i have a 91 RS 3.1 liter Camaro and i am having trouble getting the cooling fan to work. right now i have a wire running up to the positive terminal whenever i need to get anywhere. (yes i know how ghetto that sounds} wired the old fan up to the battery and it didn't work. bought a new one, tested it and made sure itt spins and threw it in with a new radiator. car still didn't want to turn the fan on when it needs to. looking at the Chiltons book there's a engine temp switch and then there's a sensor. I assume the sensor is for the gauges also, i bought a new engine coolant fan Relay and double checked fuses. there's also a manual override switch that i guess i could wire to the interior but i want to avoid that and keep it working the way it was stock. Is there anything else i should check before buying a new sensor ? what components would i be over looking?
Old Jul 5, 2017 | 11:41 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Losing Her Cool
With the key in the RUN position, but the engine not running, ground the fan switch on the engine.
Did that cause the fan to run?
If yes, the fan switch is defective.
If no, use a fused jumper
(1 amp is fine) jump that orange wire at the relay to the brown wire pin 5.
Did the relay ••CLICK••?
If yes, check for power at the
black wire with the red stripe when the fused jumper is still connected.
Was there power there?
If yes, you have a break in the line from that point to the fan connector.
Also don’t forget to make sure the ground pin in that connector still makes it to ground.
Happy Racing !
He Must Have Been Cheating - Because I Was And He Almost Beat Me.
TedRust
Dec 5, 2018 09:42 PM
LGS_18
Jul 31, 2017 07:09 AM
Claudio804
Jul 4, 2017 10:12 PM
maroe624
May 17, 2017 08:25 PM
jamieriplilb
Apr 9, 2017 03:26 PM
