Radiator Fan
Old May 21, 2017 | 08:35 AM
LGS_18's Avatar
Car: 1992 Firebird
Engine: 3.1 6 cylinder
Transmission: 700R4 automatic 4 speed
Radiator Fan
My 1992 firebird with the 3.1 has been getting up to about 230 recently in the hot weather and i realized that the fan isnt kicking on. Does anyone know where i can get an OEM fan for the car? I went to autzone and the fan they sell has a different connector. Wanted to see if i could get something with the same connector. Any help is great! Thanks!
Old May 21, 2017 | 10:17 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Radiator Fan
Are you sure it is the fan not the temp switch?
Old May 22, 2017 | 09:00 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Radiator Fan
Yeah, start by putting 12 volts to the fan and see if it works. Then work backwards and check the relay, etc. before assuming the motor is out
Old May 23, 2017 | 06:20 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fan Plan
But if you need a new one: GMpartsDirect.com
Happy Racing !
Don’t Fuss Paintin’ Your Back Bumper, Cause B4 The Race Is Over I’m Gonna Be Pushing You Out Of The Way
Old May 23, 2017 | 08:17 PM
dmm3369's Avatar
Car: 83 Z28 / 89 IROC
Engine: 350's
Transmission: T5 WC / 700R4
Axle/Gears: Posi 3.73
Re: Radiator Fan
Got all my cooling parts here.
http://www.hawksmotorsports.com/82-9...nents/cooling/
Old May 23, 2017 | 09:00 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Re: Radiator Fan
Firebird farm in MN has a bunch of parts. I believe he is on fb.
Old Jul 30, 2017 | 12:39 AM
LGS_18's Avatar
Car: 1992 Firebird
Re: Radiator Fan
the fan works when the car gets to 220 degrees but doesnt work when i put 12volts to it.
Old Jul 30, 2017 | 01:17 AM
mike135531bubba's Avatar
Re: Radiator Fan
I usually have luck finding replacement parts by just typing into Google something like "buy 1992 firebird fan"
Old Jul 30, 2017 | 01:36 AM
LGS_18's Avatar
Car: 1992 Firebird
Re: Radiator Fan
That wasnt an answer to my question but thanks
Old Jul 31, 2017 | 07:09 AM
dmm3369's Avatar
Engine: 350's
Re: Radiator Fan
