Air conditioning and fan question?
Old Jul 2, 2017 | 09:42 PM
ted-hurst's Avatar
Car: 30 Ford Coupe
I have a 88 Pontiac Formula with a 5.0 TPI/Auto . When I drive without the A/C on, the cooling fans work as like they should. The problem is the fans are not coming on when I turn on the A/C. Before, when I turned on the A/C both fans came on and ran and now they don't. I checked the fuses and changed the fan relay and still the same issue. Is there a switch in the compressor that turns on the fans? Thanks for any help.
Ted
Old Jul 3, 2017 | 12:03 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: Air conditioning and fan question?
Yes but on my 1989, its near the firewall on the air con line. If this switch is bad, neither fan will come on during air conditioning.
Old Jul 3, 2017 | 10:42 AM
ted-hurst's Avatar
Car: 30 Ford Coupe
Would it be possible to get a pic of where it's at?
Ted
Old Jul 5, 2017 | 10:05 AM
Engine: 350 TPI L98
Transmission: WC T5
https://www.thirdgen.org/forums/cool...re-switch.html
Old Jul 5, 2017 | 10:26 PM
ted-hurst's Avatar
Car: 30 Ford Coupe
Found it thanks.
Old Aug 6, 2017 | 12:35 PM
StevenB L98/LS1's Avatar
Car: 1989 Firebird Formula
Engine: 5.7 LS1
What did you find or replace? I'm fixing up an 88 for a friend. The previous owner took out the A/C system so I put a new system on already and replaced the pressure switch on the dryer and the A/C blows cold but the 2nd fan isn't working with the A/C on either. The Fan operated when grounded, I replaced the relay as well. Having a hard time finding any short in the wiring. The only thing I haven't changed yet is the passenger side manifold fan switch.
Thanks Steven
