A/C leak after new lines installed
Old Jul 14, 2017 | 02:53 PM
Johny2234's Avatar
Car: 1990 Trans Am
Engine: 383 stroker
So I recently added new a/c lines when the lines were leaking. So I replaced them and I noticed that I have a big leak from the fitting that goes to the radiator. This leak obviously wasn't there before the new lines. I re- tightened them and it continued. I then pulled off the line from that fitting and noticed that the old o-ring was stuck together with the new o-ring. I took of the old one and the leak continued. Does this fitting need two o-rings one on the line and one on the fitting. I am really confused. Please help.
Old Jul 14, 2017 | 04:07 PM
Re: A/C leak after new lines installed
Only needs one O-ring.
Replace the one that had got doubled up. Put in a completely new one. If that doesn't fix it, then one of the metal parts is damaged somehow and will have to be replaced.
Old Jul 14, 2017 | 04:20 PM
Johny2234's Avatar
Car: 1990 Trans Am
Engine: 383 stroker
Ok, I will change out the o-ring and hope everything goes good. Thanks.
