Floating temperature gauge on 1987 Merc Cougar?
Old Aug 9, 2017 | 09:20 PM
GWalcott's Avatar
Want a title? Post!
I have a 1987 V6 Cougar that normally runs at a normal temp, just below half. If I drive it for about 10 miles or more the temperature will occasionally go all the way up to the H and immediately go right back down to below half. I don't notice any difference in performance when the temperature gauge does this. I drove about 100 miles the other day and it did it several times and the car didn't overheat. I'm hoping it's a faulty temperature gauge
Last edited by GWalcott; Aug 10, 2017 at 01:15 AM. Reason: I forgot to put the make and model in the title
Old Aug 10, 2017 | 06:47 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Floating temperature gauge on 1987 Merc Cougar?
Thirdgen.org is dedicated to 82-92 f-bodies. I'd suggest a site that might be more helpful to you if I knew of one. Best of luck with your issues.
JamesC
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
ONly one way to find out, change the sensor. Other than that I would try a Cougar related board or at least a Ford related board vs a Specific third gen Camaro / Firebird forum
https://www.google.com/search?q=merc...utf-8&oe=utf-8
PTS
Nov 17, 2016 06:39 PM
PTS
Nov 17, 2016 04:41 PM
Bohemian
Nov 12, 2016 03:52 PM
Aviator857
Oct 2, 2016 03:38 PM
Piotr Zaborniak
Sep 15, 2016 10:19 AM
