Temp Gauge Reads Hot Always
Old Aug 22, 2017 | 08:53 AM
jorgeblancojr's Avatar
The needle on my temp gauge always ends up at 260 no matter when I start the car. In the mornings it'll start at 100, but in about a minute it'll slowly make it's way back up. I've changed the switch and the gauge, but I'm still seeing the same results. Any help? Thanks.
Old Aug 22, 2017 | 12:19 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Temp Gauge Reads Hot Always
What kind of car, engine, modifications do you have.
Old Aug 22, 2017 | 12:20 PM
305 TPI. It's all stock.
Old Aug 22, 2017 | 01:05 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Have you checked the wiring for the gauge probe? The temp probe wire might be touching bare metal. Pop the hood and look at your driver side of your engine. On the head between cylinders 1&3 there is the temp probe for the dash gauge. The wire could have slipped off most likely and is touching bare metal.
Old Aug 22, 2017 | 01:22 PM
The wire for the switch? I checked it, it's connected to it.
Old Aug 24, 2017 | 11:59 PM
Have you followed the wire slightly just to see if it happened to have got burnt on a header primary?
