91 Camaro RS Overheating
Old Sep 13, 2017 | 10:53 PM
cj.fletcher91's Avatar
So My 91 RS (305) began to overheat. Naturally i replaced the thermostat first (185). I noticed the fan was jogging on the motor shaft so i replaced it with a universal fan (hayden brand). I did a radiator flush and it is STILL overheating (260+). There is no water coming from the weephole of the water pump, this is the only part of the cooling system i have not changed or flushed out. I do live in Phoenix where its 110+ for 5 months of the year which is when this issue popped up. is it just running hot due to outside temp. Or is there something I'm missing or could try? Anything will help at this point
Old Sep 15, 2017 | 01:48 AM
LiveIt!'s Avatar
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Re: 91 Camaro RS Overheating
Is your cooling fan kicking on at all and if it is ,when?
Old Sep 15, 2017 | 12:56 PM
I have it wired to turn on with the car.
Old Sep 15, 2017 | 02:44 PM
LiveIt!'s Avatar
Fans on and still overheating? Wow! I wonder if there's something wrong with your pump or if coolant is even circulating thru the engine, can any other members chime in?
Old Sep 16, 2017 | 11:11 AM
Jp's camaro's Avatar
Car: 1991 rs, 1985 z28
Engine: 3.1 v6, 305 tpi
Transmission: 700r4, 700r4
Axle/Gears: 3.23, 3.23
When its warm enough for the thermostat to open try to squeeze the top hose to see if its flowing coolant from the thermostat
Old Sep 16, 2017 | 02:16 PM
Also did you check to make sure the air dam is still there
