1986 V-6, 2.8 Coolant Temperature Sensor
Old Nov 9, 2017 | 11:40 AM
bikermark49's Avatar
1986 V-6, 2.8 Electric fan energizes when engine is cold and continues to run. Check engine light on. After a warm restart fan will not energize even with hot engine.
Which is the proper coolant temp sensor? (I see two near thermostat on manifold) Could this be the problem?
Old Nov 9, 2017 | 11:43 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1986 V-6, 2.8 Coolant Temperature Sensor
What codes are you getting 15 ?
