Temp fluctuations
Old Jun 7, 2018 | 08:02 PM
Wesley Hooper's Avatar
Car: 1988 Camaro
Temp fluctuations
I have an 88 with the stock 305 and put a new radiator in a few years ago and just replaced the bypass valve. The coolant and reservoir are full to the proper amounts. Normally while running it's at the first line on the temp gauge but recently its jumping up to the middle line and back down to the first line the whole time I'm driving. Is this fine as long as it's not overheating?
Old Jun 7, 2018 | 11:03 PM
PaulyC's Avatar
Re: Temp fluctuations
If it’s not overheating it won’t cause any damage but it’s not normal. I would initially suspect a sticky thermostat. Bypass valve should have no relation to this.
Old Jun 7, 2018 | 11:34 PM
Car: 1988 Camaro
Thank you. I will check that out
RED85TPI
Jun 29, 2014 03:47 PM
X-Ravin
Jun 1, 2010 03:52 PM
5.7RamJet
Apr 2, 2007 11:27 AM
3.1 firebird
Jul 23, 2002 02:10 PM
