Radiator fan won't come on
1986 Oldsmobile Cutlass Ciera L4
I have replaced the relay, thermostat, thermostat sensor, hooked the fan to the battery to make sure it works, flushed out the radiator and engine block with a hose (engine was cool), ran it full of coolant to make sure water pump was working, why can't i get it to turn on still? (currently running it with no thermostat and heat on high...)
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Radiator fan won't come on
Try looking at the schematic in a service manual. You won’t find the answer on tgo.
xbazzarex
Oct 1, 2016 01:02 PM
