radiator
Old Oct 22, 2018 | 02:10 PM
Spenc's Avatar
Car: 84 z
Transmission: 700
Axle/Gears: auto overdrive
radiator
after a long drive the 2 core aluminum radiator is to cool at the cap but untouchable on the other side. ??
Old Oct 23, 2018 | 08:26 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: radiator
Are you overheating?
Have you tried changing your thermostat?
What investigation have you done?
Old Oct 23, 2018 | 09:05 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: radiator
core blockage maybe try flushing it
Old Oct 24, 2018 | 06:45 PM
Spenc's Avatar
Car: 84 z
Transmission: 700
Re: radiator
witch core do you mean please?
Old Oct 24, 2018 | 06:59 PM
Spenc's Avatar
Car: 84 z
Transmission: 700
Re: radiator
thanks there... changed. the 195 for the 165 and it ran even coo... and with card board over half the radiator...maybe 110. so I well pull the stat out... change the 16 to the correct 15 psi. cap..... drop the coolant a little in the radiator and check the flow. it's a new pump also but I've had many bad new parts. another fella thought the core (heater?) cold be blocked but I don't think so. I have good inside heat. thanks again. sounds like a faaaast car you got there.
Old Oct 26, 2018 | 04:46 PM
GeneralDisorder's Avatar
Re: radiator
Sounds like you gauge isn't accurate.
GD
Old Oct 26, 2018 | 05:41 PM
Spenc's Avatar
Car: 84 z
Transmission: 700
Re: radiator
bought the last new gauge in the country about 5 years ago and with the new sensor I've seen it go the full spectrum over the summer. with no stat it won't get past 100 degrees at 48 degrees ambient temp. I bought a laser temp unit to check with but think it could also be the timing. thanks again.
383RAT
Aftermarket Product Review
Jun 4, 2018 01:24 PM
Tibo
Feb 11, 2017 09:55 PM
Bohemian
Nov 12, 2016 05:45 PM
keithl1967
Oct 4, 2016 06:10 PM
b2010
Sep 28, 2016 07:28 PM
