Ice in radiator
Car: 1987 Trans Am
Engine: LG4 305
Ice in radiator
What a nightmare. I replaced my old busted factory radiator with a new one last night, half filled it with concentrate anti freeze, half with distilled water. I didn't bother running the engine because it was getting dark and I couldn't exactly check for leaks. So today I go out and despite me THINKING I got my 50/50 mix accurate, there's icy sludge in my radiator! It's not a solid chunk of ice, but it's definitely icy - like an exotic green summer cocktail. .
My question is, what should I do? I know once I run the engine with the radiator cap off, there will be some air in the system to bleed out. I'm thinking I should just let her run, have all that stuff warm up and melt, and pour in some more 100% antifreeze? Since I haven't run the engine yet, I don't think any of that nonsense has gotten into the block, so that should be ok. But does anyone have any experience with this? Thanks in advance.
Axle/Gears: 10 Bolt 2.73 Open
Re: Ice in radiator
If it's not frozen solid, probably no harm done (guess).
It probably got slushy because you didn't run the engine, and mix the coolant and water (guess).
I'd proceed as if it didn't happen. Run it, mix it, top it off. If you think you got the 50/50 right, then top off with 50/50.
If something is damaged, it will show up soon enough.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Mixed Drinks
Always a good idea to mix the antifreeze & water before pouring it into the radiator.
Happy Racing !
Funny Car Fun Fact: Dual magnetos apply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
Happy Racing !
formula forever
Aftermarket Product Review
Jun 30, 2009 09:47 AM
IROCME
Theoretical and Street Racing
Dec 11, 2001 12:13 AM
91rscruiser
Nov 11, 2001 02:02 PM
