Temp gauge acting strange
Old Apr 11, 2019 | 06:32 PM
JonJon5.0's Avatar
It seems as my temp gauge only works when it feels nice outside like between the weather of 60-78 Degrees...However when it is cold outside lower than 30 Degrees my Temp gauge won’t Function any Ideas?
Old Jun 10, 2019 | 04:12 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cold Shoulder
The cold weather won’t be back for a while therefore you’ll have plenty of time to prepare for this test:
Disconnect the
green wire from the temp sensor.
Clip in a 100 ohm resistor from that wire to the negative battery terminal.
Turn the key to RUN.
If the gage is good it will read about 220°.
If it reads erratically you will know the gage is at fault.
Happy Racing !
What’s With The Stupid Truck And SUV Manufacturers That Mount Headlights Too High So They Don’t Illuminate The Road, But Only Shine In Your Eyes
Old Jun 10, 2019 | 06:27 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: Temp gauge acting strange
Nina always has the best tests.
For now, you can practice removing the gauge cluster. Remove it and inspect the printed circuit on the backside. If the printed circuit is degraded/damaged/delaminating, your gauges won't work properly. You can also replace the burned-out bulbs while you have it apart.
Here you can see how the printed circuit can de-laminate. Also note the verdigris forming, indicates damage from moisture.
jerzeydevil
Mar 6, 2013 02:28 PM
pianiy
Jun 12, 2002 11:59 AM
mirage2991
Feb 1, 2001 08:37 AM
