305 heads plug
Old Aug 12, 2020 | 12:55 AM
Alexander1j's Avatar
305 heads plug
Does anyone know the official name of this plug and any lead to find a much more flat version of it
Whats the official name of this plug and do
Driver side went in smooth.
Does anyone know where i can find a flat version.
Its stopping me from putting on some headers
Old Aug 12, 2020 | 06:30 AM
Re: 305 heads plug
Hold on and sit down while I give you this hard memorization lesson.
Its official name is "plug".
You can pick one up at the hardware store. It'll be in the section of miscellaneous brass fittings. It's 3/8" pipe (NPT) which is a bit of an odd size at hardware stores, not as wide a variety of fitting styles in that size as 1/4" or 1/2", but they should have what you want. If all you can find is a square- or hex-head one, and you want "flat", cut the drive off, sand it nice and flat, and cut a wide deep screwdriver slot in it. Use about 6 wraps of Teflon tape on it when you put it in.
Problem you will have is, that SHOULD be where the switch for the electric fan goes, and rather than a plug, it SHOULD be a fan switch. You might want to notch the header flange out instead, if they're that poorly designed and executed, to where they don't fit the car properly.
Old Aug 12, 2020 | 10:58 AM
GeneralDisorder's Avatar
Re: 305 heads plug
Being that's a V-belt TPI car..... very similar to my 86, It should have a single electric fan that's run by the ECU..... and AFAIK there are no fan switches. There's a switch in the front of the TPI base for the cold start injector that looks similar to that. Or perhaps the orange engine came from the something else and this is left over from that?
Edit - could be an 87 with dual fans? And that's the secondary fan switch? Center bolt valve covers would seem to agree.
GD
Old Aug 12, 2020 | 11:39 AM
Re: 305 heads plug
GD
it is a 86, i bought the car a year ago but havent had much time to work on it, till recently. The fan automatically starts when i start the car so the guy i bought it from diffenitly either rewired some stuffor like u said could be a different engine, it also has a cam and idling problems, I've looked up on it and read it could be air leaks so intake well be next....eventually. But when i removed the original manifolds i found out this guy didn't have any gaskets, hoping not counting on it but maybe that might help with idling.
Old Aug 12, 2020 | 11:47 AM
Re: 305 heads plug
i was thinking of just unscrewing this plug even tho i might lose a bit of coolant and putting some thing in there to slow it down, move the headers up then screw the plug back in instead of banging and cutting here and there rather replace some fluid then risk nicking something important, was just curious if it COULD be replaced. A 24 mm deep socket got it out, wasnt even that tight either😦 but ill look into what you said, i appreciate to help and advice, thanks.
Alexander1j
Aug 13, 2020 07:49 PM
frebor72
Apr 8, 2020 12:06 AM
silentkillzr
Mar 12, 2014 12:18 AM
evilemokid94
Jun 6, 2010 03:05 PM
mrr23
Feb 28, 2004 05:07 PM
