Water pump direction question
Old Sep 15, 2020 | 05:39 PM
caddyescalade's Avatar
Hello, I have a new to me 3rd gen that had a 350 swap from an original 305 car before I bought it. The guy swapped many parts over from the original 305. I suspect the water pump was also swapped. My alternator is on the left, so I’m wondering if the water pump is spinning the right direction or not on the 350 as I have a bit of a colony issue. Installed a new aluminum rad with 1” tubes and I’m still getting warm while driving at higher rpm. OEM Single Electric fan works fine, no issues at idle.
how do I tell if the water pump is correct for the direction? Thanks
Old Sep 15, 2020 | 06:02 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Water pump direction question
Take the rear cover off the pump and look. If serpentine will need reverse rotation.
Old Sep 16, 2020 | 12:19 AM
thanks. I believe I have 3 separate belts as I have a/c as well.
Old Sep 20, 2020 | 09:38 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Serpentine is one belt and pump would be reverse rotation. V-belt is normal rotation.
mcloudy21
Sep 15, 2018 11:18 PM
dixie wrecked
Feb 1, 2016 01:28 PM
JB22
May 25, 2006 03:33 PM
len
Jan 31, 2002 05:56 AM
