California Fan Switch
Old Nov 18, 2020 | 11:21 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
I was looking at the usual parts websites (JEGS, Summit, and regular auto parts stores) for a new in-block switch for my fans. Did I miss something where I cannot buy a switch that turns on the fans below 230 degrees anymore in CA?
Old Nov 18, 2020 | 12:17 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: California Fan Switch
If you are looking for a standard switch for our cars get a 1989 Turbo TA switch 212 on and 205 off
Fan Switch 212 on 205 off (PNs SW555, TS136, 35946, 1S4394, 3053190)
Old Nov 18, 2020 | 12:24 PM
ULTM8Z's Avatar
Summit has this thing now about buying parts in CA...
When you go to check out, they make you sign a form saying your car is either pre-1965 or off-highway use only.
You can bet that data is being collected for... <ahem>... "later use".
Old Nov 18, 2020 | 12:27 PM
midias's Avatar
Ebay or rock auto just plug in a PN
Old Nov 18, 2020 | 12:53 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Just ordered one off of Rock Auto. Thank you for the part numbers.
Old Jan 2, 2021 | 09:39 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
How about part numbers please,
radiator fan switch, turn on approx. 212* F, 1989 LB9, 305 TPI with AC and Dual electric fans?
NOT counting the temp gauge sending unit, does this cooling system fan circuit use, 1 temp sensor (location, part # please) to report to the ECU? And 1 fan switch, (location, part # please) to turn on the fans(in case ECU fails)?
Thanks.
Marcos123
Mar 22, 2013 01:19 AM
ERIC'86IROC
May 29, 2002 02:57 PM
Fbird88
Feb 27, 2002 10:42 AM
Kao91
Aftermarket Product Review
Feb 22, 2002 10:31 PM
