Temp guage coolant sensor.
Recently when doing a reasonably thorough coolant flush, (305TPI) I noticed when I took out the knock sensor and the drain plug on the left side of the block, that both holes were so blocked up with gunk, nothing flowed out until I poked a screwdriver in to dislodge it all then the old coolant came pouring out. I didn't touch the coolant sensor for the gauge but was wondering, could it too be all gunked up in the same way and if so would that make it so the gauge takes longer to show the actual temperature?
Just trying to figure out if my car actually takes as long as the gauge says to get to temp or if the sensor is faulty or doesn't have direct contact with coolant due to being gunked up ?
Re: Temp guage coolant sensor.
That sending unit is in fairly intimate contact with the head casting, so it shouldn't matter as much, if at all.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Sludge usually collects at the bottom - like it does in the overflow bottle - & it can't really 'settle' in the head like it can at the bottom of the block. As long as it's working;Temp gauge sending unit should be fine !
OddJack
May 22, 2010 11:01 PM
