Is Coolant Temp. Sensor and Temp gauge Sender the Same?
Old May 22, 2010 | 08:04 PM
OddJack's Avatar
I need to change the Coolant Temperatur sensor, is it the same as Temp. Gauge sender?
Do you know if Duralast is good or needs to be ACDelco or other Brand?
Old May 22, 2010 | 08:07 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Is Coolant Temp. Sensor and Temp gauge Sender the Same?
Coolant temp sensor is a 2-wire, temp gauge sender is 1-wire.
Old May 22, 2010 | 08:16 PM
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
dont get the dontlast get the ac delco
Old May 22, 2010 | 08:26 PM
OddJack's Avatar
Chilton guide has listed only coolant temp sensor. Where is the sender sensor?
Coolant sensor is right by the intake, right?
Old May 22, 2010 | 11:01 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Yes, 2-wire (yellow/black) is on front of intake facing radiator next to cold start temp/switch.
Engine temp gauge sender is in driver side head between #1 & #3 plugs, single green wire.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
85Special
Sep 3, 2015 04:21 PM
willyjoejr
Sep 3, 2015 09:26 AM
