Cooling hysterisis 1989 TPI
Car: IROC-Z Z28
Engine: 5.7L TPI
Transmission: AT
Axle/Gears: 2:73
I have a 5.7L TPI. I have a new ecm that turns the fan on at 195* I need to know if the stock cooling temp sender is compatible with a 180* thermostat ? Is this correct hysteresis ? Thank you
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Cooling hysterisis 1989 TPI
What temp sender are you referring to the secondary head switch ?
if primary fan was tuned to come on at 195f a 180 or 195f thermostat works fine.
operating temp might be close to 200f.
Engine: Lb9
Transmission: M20
Nothing in the block, cts for the ecms control in front of the intake manifold.
seconday fan sw passenger head between 6&8 cylinder. And gauge in head on drivers side between 1&3 cylinder
