Iroc Z loud rattling noise from engine bay
Old Dec 19, 2021 | 05:45 PM
OzzieLAIrocZ's Avatar
Car: 1987 IROC-Z28
Engine: 5.0 LB9
Transmission: 5 speed
Whats up ThirdGens anyone possibly have a diagnoses for this problem im having ? Loud rattling noise coming from engine bay. I checked it out and it seems to be like the fan is rattling violently for some reason . Once i turn the car off you can still hear the rattling noise as the fan is slowing down to come to a complete stop.
File Type: mov
Old Dec 19, 2021 | 06:07 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Iroc Z loud rattling noise from engine bay
probably the outer ring around the fan blades is broken-should be easy to find a replacement,lots of mid-80s-mid '90s GM cars used the same fan:FWD cars,early v6 and non-AC 4th gen to name just a few.
Old Dec 19, 2021 | 08:09 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
I would say your violently shaking fan appears to be the culprit. Disconnect the relay temporarily and verify the noise goes away. Either something is broken and the blades are hitting, or the fan motor itself is borked. Fortunately, you can replace just the motor and it's not very expensive or difficult to do if it's bad.
MorbidHobo
Sep 5, 2007 05:36 PM
graphicideas1
Oct 18, 2006 01:04 PM
z2885er
May 24, 2005 11:45 PM
camaro 670087
Jul 30, 2003 10:55 AM
pookey
May 10, 2001 12:12 AM
