Cooling Fan Lower Temp Switch?
Old Mar 14, 2022 | 11:23 PM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Hey everybody,
Spring is here, and I finally got myself back in the garage. Problems abounding.
Firstly, is there a kit or a plug and play replacement switch for the stock cooling fan temp switch?
I'd like to get one that turns on at 200 and off at around 185, but all the ones I've seen posted on here are from long ago threads, and the part no longer exists. I was primarily looking for the JET switch mentioned on here, but no luck anywhere.
I saw Hawks has one, but it runs a bit too cool for my taste. I believe on at 180 off at 165 or something.
Anyone have any suggestions? Or could you point me in the right direction?
Thanks!
Old Mar 15, 2022 | 01:01 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Cooling Fan Lower Temp Switch?
Standard Motor Products TS-136. It's the OE switch for an '87 Grand National, supposedly comes on at 208f and off at 188f. Manufacturer says on activation occurs between 204-220f. I got mine at rockauto.
Old Mar 15, 2022 | 07:11 AM
Annihilate's Avatar
Engine: 5.0
Still better than the stock temps, sheesh. Thanks for the quick tip!
Old Mar 15, 2022 | 09:35 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
where is this switch located? I thought that the fan clutches were thermally activated.
Old Mar 15, 2022 | 10:21 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
wells sw555 or if tpi you can set desired on/offs with tuning easily.
summit has a wide verity of single wire 3/8 npt fan switches.
Old Mar 15, 2022 | 03:29 PM
Annihilate's Avatar
Engine: 5.0
But you can only tune one fan, can you not?
Old Mar 15, 2022 | 03:31 PM
Engine: Lb9
Transmission: M20
Primary is ecm controlled
Old Mar 15, 2022 | 03:34 PM
Engine: Lb9
Transmission: M20
Could probably wire the primary fan relay to control the secondary fan relay
Old Mar 15, 2022 | 03:44 PM
72buickgs's Avatar
Car: 1984 Trans AM
I guess that u have dual electric fans. Now I understand about changing the sensor.
Old Mar 18, 2022 | 05:08 PM
Annihilate's Avatar
Engine: 5.0
Where do you see the information about when it comes on and shuts off? I can't seem to find it anywhere...
Have you checked when it comes on for you?
Old Mar 18, 2022 | 07:25 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
On at 208f, off at 188f was what somebody here on tgo said. Activation between 204-220 was a manufacturer response on summitracing.com. I actually haven't confirmed it yet, I got my car drivable in November and I was in stop and go city traffic the only time it got to 220f and refused to go further. The way I figure it, stock is practically useless and this seemed like a decent compromise for a 195f thermostat car. Fyi you'll need a new connector pigtail with the switch, mine crumbled into dust like pretty much everyone else's.
Old Mar 18, 2022 | 11:11 PM
Annihilate's Avatar
Engine: 5.0
I actually replaced the pigtail and put in a stock sensor last year chasing down a fan issue.
Did solve my problem, but the stock kick on time is no good lol.
Old Mar 19, 2022 | 12:59 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Search Ebay for "200'F electric cooling fan thermostat"
Fan on at 200, off 185. $22 free shipping. This link might work
https://www.ebay.com/itm/23418079974...Cclp%3A2332490
Old Mar 22, 2022 | 02:59 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I went from single fan to TPI dual with a separate relay / power source for the second fan....... i really don;t see how the one tiny fan by itself can cool the motor well..it stayed on almost constantly keeping temperatures "constant". but never lowered it past a certain temp...........but the coolant didn't reach the temperature to activate the second fan at idle. GM should have made both fans come on at the same time..........so I wired the second fan to come on at the same time as the first. and also swapped to a LS1 shroud...
I can literally watch the gauge go down now once the fans kick on lol
I spliced the computer trigger wire into a mechanical temp switch closer to the thermostat (kinda like a manual overrde switch that people install).... the computer signal for me serves as a back up trigger in case the fan switch goes bad, and also for an ac fan trigger.
I used a I think its a TS85?? standard brand from Oreil'lys which is on at I believe 220? its kinda close to the computer temp but still it comes on sooner.
AC also blows much colder with the dual fans pulling air over the condenser.
I realize I could have programmed the ecm to turn on sooner
but
1. don;t know how to do that,
B. Its a bit costly to pay for that to be done
Thrice. I like to make things excessively complicated.....
Old Mar 23, 2022 | 10:09 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Great info! I’ll be back
JesterHead1651
Aftermarket Product Review
Aug 30, 2008 11:35 AM
jaykar
Oct 5, 2005 11:18 AM
tom3
Sep 19, 2004 10:13 AM
Barry85Iroc
Aug 30, 2003 12:48 AM
Rallyssport
May 24, 2001 06:55 AM
