Brand new fan hum Screams above 4500
Car: 1982 z/28 Right hand drive
Engine: 377 AFR195 750DP Solid cam 10.25:1
Transmission: TH/350 3200 stall spohn conversion
Axle/Gears: 10 bolt 3.42:1 Eaton Trutrac.
Bought a brand new clutch hub from Gm and a new fan blade ,,had it on the car 6 months, first start up no problems but when reved the hub makes a shuddering noise and freaks out.
never saw this with a clutch fan let alone a brand new one. Had nothing but trouble with something so simple.
new Water pump hub was drilled off center, its wobbled. put ANOTHER new pump on. Now the Brand new Hub is Crap.
I will go back to a Fixed blade flex fan, they dont fail.
Car: 1983 Z28
Engine: 385 Fastburn
Re: Brand new fan hum Screams above 4500
Got a pile of youtube videos with flex fans going through the hood that beg to differ
Sounds like you just got some bad parts. It happens. Especially if buying through a parts store, sometimes they don't check returned parts and just re-box em and sell them again.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Time to convert to electric and be done with it
I spoke to Davis Craig and the electric fans in Australia where its common at 110f temp day 4 months a year is not good.
I had a 16 inch electric and cooked the 408sbc.
i was ok on the road but first traffic lights i was in panic mode trying to get going again.
i went back to the big flex fan that is like a windmill.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
too bad about that water pump being miss-manufactured and ruining the fan clutch...that is one of the problems maintaining "legacy"cars-craptastic new parts...I have had OEM type flex fans on some of my vehicles and no problems other than HP usage at high RPM.Some of the street rod type flex fans are pretty bad
The "big three"and AMC installed a lot of flex fans during the 1968-82 years-Ford had a recall in the '70s for faulty flex fans that would throw blades.
The "big three"and AMC installed a lot of flex fans during the 1968-82 years-Ford had a recall in the '70s for faulty flex fans that would throw blades. Thread
Iroc'nthe87
May 18, 2013 05:42 PM
