cold case fan connector
Old Oct 7, 2022 | 03:38 PM
lewandom's Avatar
Car: 84 Z-28 Camaro, 2022 Chevy 2500
Engine: 383
I recently purchased a cold case radiator with 2X 12" fans, and I don't recognize the connectors they used, dose anyone know which connector they used and where I can get them? its a socket style connector with 1 connector turned 90* to the other
Old Oct 8, 2022 | 01:39 PM
Re: cold case fan connector
Photo would help
Old Oct 10, 2022 | 06:58 AM
lewandom's Avatar
Engine: 383
sorry here are a few pics
Old Oct 10, 2022 | 07:41 AM
I don't recognize it. Thought I might but...
Vorteciroc might. I couldn't say.
Can't believe Cold Case doesn't supply the mating connector; that's kinda weird. Have you contacted them?
If I couldn't get its mate I'd probably just do away with it and replace it with an Aptiv Metri-pack 480 series or thereabouts. You can get all the parts & pieces at Mouser easily enough.
Old Oct 10, 2022 | 08:08 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
That's a pretty common style connector found on Spal fans as well. They sell various wiring and relay kits as well as a jumper kit that would connect to what you have pictured. Or, cut it off and put your own preferred connector on.
https://www.summitracing.com/parts/s...4aAlErEALw_wcB
Old Oct 10, 2022 | 02:06 PM
lewandom's Avatar
Engine: 383
sweet, thanks, I also got pro-flo 4 EFI from edelbrock and it has dual fan controllers built into it so I was going it wire them into the EFI....now I need to re-read the manual to see if the relays are wired in already or I need to get some lol...parts slowly coming togeather
pirateofms
Car Audio
May 30, 2022 11:38 PM
dlinger
Apr 7, 2022 09:19 AM
Tuned Performance
Jul 3, 2019 05:24 PM
SgtSkip
Jan 21, 2003 05:43 PM
